Zum Hauptinhalt wechseln
Nikon Coolpix S800c Motherboard Replacement Guide
Was du brauchst
  1. Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: Schritt 1, Bild 1 von 2 Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: Schritt 1, Bild 2 von 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 2, Bild 1 von 2 Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 2, Bild 2 von 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Motherboard Replacement Guide, Motherboard: Schritt 3, Bild 1 von 1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 4, Bild 1 von 1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 5, Bild 1 von 1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 6, Bild 1 von 3 Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 6, Bild 2 von 3 Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 6, Bild 3 von 3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 7, Bild 1 von 2 Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 7, Bild 2 von 2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 8, Bild 1 von 2 Nikon Coolpix S800c Motherboard Replacement Guide: Schritt 8, Bild 2 von 2
    • Pull the motherboard off of the main body of the camera.
Abschluss
Soldered wires attaching the motherboard to the camera body will need to be disconnected at the motherboard-end and the new wires on the replacement motherboard will need to be soldered on. To reassemble your device, follow these instructions in reverse order.
Kenneth Huynh
133 Reputation
1 Anleitung geschrieben
Baylor, Team S2-G6, Johnson Spring 2018 Mitglied von Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 228
