Was du brauchst
Start by locating the Battery Terminal on the bottom of the Camera, push the slider over to let the door flip open.
The SD card will be the smaller of the two cards in the battery terminal. Press down on the SD card and it will pop out enough for you to grab it and remove it. Then put another SD card in its place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
