Zum Hauptinhalt wechseln
Nikon Coolpix S9700 Memory Card Replacement
  1. Nikon Coolpix S9700 Memory Card Replacement, Memory Card: Schritt 1, Bild 1 von 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: Schritt 1, Bild 2 von 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: Schritt 1, Bild 3 von 3
    • Power off the S9700 and situate it so that it is upside down.
    • Place your finger on the compartment door.
    • Gently push toward the front of the S9700.
    • The compartment door should spring open by itself.
  2. Nikon Coolpix S9700 Memory Card Replacement: Schritt 2, Bild 1 von 3 Nikon Coolpix S9700 Memory Card Replacement: Schritt 2, Bild 2 von 3 Nikon Coolpix S9700 Memory Card Replacement: Schritt 2, Bild 3 von 3
    • Locate the memory card. Be careful not to mistake it for the battery.
    • Push down on the memory card until it won't go down further. Don't push too hard to avoid damaging your camera
    • Release your finger and the card will pop up out of its compartment.
  3. Nikon Coolpix S9700 Memory Card Replacement: Schritt 3, Bild 1 von 2 Nikon Coolpix S9700 Memory Card Replacement: Schritt 3, Bild 2 von 2
    • Grab your memory card with two fingers.
    • Gently pull up and your memory card will come out.
Abschluss
Matt Staubus
849 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 9-5, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 534
