Zum Hauptinhalt wechseln
Nikon D3100 Lens Mounting Ring Reseating/Replacement
Was du brauchst
  1. Nikon D3100 Lens Mounting Ring Reseating/Replacement, Lens Mounting Ring: Schritt 1, Bild 1 von 1
    • Remove the 6 Phillips screws on the front of the lens mounting ring.
  2. Nikon D3100 Lens Mounting Ring Reseating/Replacement: Schritt 2, Bild 1 von 1
    • Carefully lift the mounting ring straight up.
    • Three unfastened metal plates lie under the lens mounting ring, be very careful lifting it up as to not disturb them.
  3. Nikon D3100 Lens Mounting Ring Reseating/Replacement: Schritt 3, Bild 1 von 2 Nikon D3100 Lens Mounting Ring Reseating/Replacement: Schritt 3, Bild 2 von 2
    • Reseat or replace the lens mounting ring and reassemble.
    • The locating pin on the right of the camera will help place the mounting ring properly.
    • The small metal plates marked in the image are not fastened and may displace if the camera if tipped or bumped. Be sure these are properly in place before reassembly.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Taylor
1.165 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 16-6, Watkins Winter 2015 Mitglied von USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 4,097
