Einleitung
If you can see black rings around the outside of the image preview, the lens may not be mounted correctly or the lens mounting ring has worn down and no longer holds the lens in position. If you have this problem use this guide to reseat or replace the lens mounting ring.
Werkzeuge
Ersatzteile
Remove the 6 Phillips screws on the front of the lens mounting ring.
8 weitere Nutzer haben diese Anleitung absolviert.
