Einleitung
This guide will teach you how to open up your flash safely and replace the flash pin that holds the flash upright.
Was du brauchst
Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
Pry off the back plastic of the flash compartment using the plastic opening tool.
On the left of the camera you will see a metal spring.
Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
4 weitere Personen haben diese Anleitung absolviert.
