Einleitung
The mainboard controls all of the software on the Nikon D40. A faulty mainboard can cause problems that will require a new board. This guide will show you how to replace the camera's mainboard.
Was du brauchst
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
Use the plastic opening tool to release the ribbon cables attached to the mainboard.
5 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
