Zum Hauptinhalt wechseln
Nikon D40 Viewfinder Replacement
Was du brauchst
  1. Nikon D40 Viewfinder Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Viewfinder Replacement: Schritt 2, Bild 1 von 2 Nikon D40 Viewfinder Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Viewfinder Replacement: Schritt 3, Bild 1 von 1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Viewfinder Replacement: Schritt 4, Bild 1 von 1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Viewfinder Replacement, Viewfinder: Schritt 5, Bild 1 von 1
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
  6. Nikon D40 Viewfinder Replacement: Schritt 6, Bild 1 von 1
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
  7. Nikon D40 Viewfinder Replacement: Schritt 7, Bild 1 von 1
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
  8. Nikon D40 Viewfinder Replacement: Schritt 8, Bild 1 von 1
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
  9. Nikon D40 Viewfinder Replacement: Schritt 9, Bild 1 von 1
    • The viewfinder has been removed!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Amy Chen
193 Reputation
1 Anleitung geschrieben
Cal Poly, Team 6-19, Maness Winter 2014 Mitglied von Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 3,239
