Zum Hauptinhalt wechseln
Nikon D5100 Battery Door Replacement
Was du brauchst
  1. Nikon D5100 Battery Door Replacement, Battery Door: Schritt 1, Bild 1 von 3 Nikon D5100 Battery Door Replacement, Battery Door: Schritt 1, Bild 2 von 3 Nikon D5100 Battery Door Replacement, Battery Door: Schritt 1, Bild 3 von 3
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: Schritt 2, Bild 1 von 3 Nikon D5100 Battery Door Replacement: Schritt 2, Bild 2 von 3 Nikon D5100 Battery Door Replacement: Schritt 2, Bild 3 von 3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: Schritt 3, Bild 1 von 3 Nikon D5100 Battery Door Replacement: Schritt 3, Bild 2 von 3 Nikon D5100 Battery Door Replacement: Schritt 3, Bild 3 von 3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: Schritt 4, Bild 1 von 1
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: Schritt 5, Bild 1 von 2 Nikon D5100 Battery Door Replacement: Schritt 5, Bild 2 von 2
    • Turn on the camera to check that the battery is properly secure.
Ziellinie
Michelle Tran
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 23-1, Green Winter 2015 Mitglied von Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 2,767
