Einleitung
The rear panel protects the motherboard and other components inside the camera and houses controls like buttons and dials. This guide will teach you how to remove and replace the rear panel.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a Phillips #00 screwdriver, remove 5 exposed screws from around the perimeter of the camera.
Using a fingernail, gently peel back the black rubber thumb grip, which is attached to the chassis with a strong adhesive, and remove the concealed screw underneath it.
Carefully peel back the black rubber hand grip, which is attached to the chassis with a strong adhesive, and remove the two screws concealed underneath.
Using a spudger, pry off the diopter adjustment dial cover and remove the screw underneath.
Next, remove the three Phillips screws around the viewfinder.
Remove the dark orange ribbon cable attaching the rear panel to the motherboard by flipping the black plastic clasp up, away from the motherboard, and pulling the cable out of its white casing in the direction of the cable.
Remove the silver 16-pin cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
At this point, the rear panel is fully separated from the main body of the camera.
7 weitere Nutzer haben diese Anleitung absolviert.
