Einleitung
In addition to the yellow battery tab, the battery door holds the camera's battery and ensures that it does not fall out. If the battery door becomes damaged or is missing, it should be replaced. It is also necessary to remove the battery door when adding certain accessories to the camera.
Was du brauchst
Turn the camera on its bottom to reveal the battery door.
Open the battery door.
Using a spudger or other prying tool, gently pop the battery door off of its hinge.
