Einleitung
Make sure to have your soldering iron ready prior to replacing the screen. This will make the process go faster as the time it takes to heat the soldering iron varies.
Was du brauchst
Fully open the LCD panel so that its screws are easily accessible.
Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
Using tweezers, unplug the smaller cable.
15 weitere Personen haben diese Anleitung absolviert.
8 Kommentare
To isaac: no. The exterior glass is separate from the LCD.
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
