Zum Hauptinhalt wechseln
Nikon D610 Battery Replacement
Was du brauchst
  1. Nikon D610 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: Schritt 2, Bild 1 von 3 Nikon D610 Battery Replacement: Schritt 2, Bild 2 von 3 Nikon D610 Battery Replacement: Schritt 2, Bild 3 von 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: Schritt 3, Bild 1 von 2 Nikon D610 Battery Replacement: Schritt 3, Bild 2 von 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Abschluss
Daniel Eagan
606 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-4, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
This is my kind of fixing )
Loic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,418
