Einleitung
Remove the bottom cover to access most components inside the D70.
Was du brauchst
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Carefully pull the bottom cover to separate it from the body of the D70.
Remove the bottom cover from the D70.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
