Einleitung
Use this guide to replace a broken memory door.
Was du brauchst
Open the memory door by pushing the memory door retainer away from the LCD.
Remove the two 2.8 mm Phillips screws securing the memory door to the rear case.
Remove the memory door from the D70.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
