Einleitung
Use this guide to replace a cosmetically damaged port cover or to install a new rubber port seal.
  1. Use your finger tip to pull the battery release tab toward the center of the D70.
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Pull the battery out of the D70.
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Remove the following eight screws securing the bottom cover to the D70:
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Carefully pull the bottom cover to separate it from the body of the D70. Remove the bottom cover from the D70.
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  6. Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  7. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  8. Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  9. Carefully pull the sides of the rear cover away from the body of the D70. Carefully pull the sides of the rear cover away from the body of the D70.
    • Carefully pull the sides of the rear cover away from the body of the D70.
  10. Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught. At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  11. Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
    • Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
  12. Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  13. Remove the two 4.3 mm Phillips screws on the face of the front cover.
    • Remove the two 4.3 mm Phillips screws on the face of the front cover.
  14. Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
    • Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
  15. Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch. Pull the automatic/manual focus switch away from the front cover.
    • Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
    • Pull the automatic/manual focus switch away from the front cover.
  16. If present, remove the plastic cover from the lens mount.
    • If present, remove the plastic cover from the lens mount.
  17. Pull the front cover away from the D70.
    • Pull the front cover away from the D70.
  18. Remove the 3.8 mm silver Phillips screw securing the port cover to the side of the D70.
    • Remove the 3.8 mm silver Phillips screw securing the port cover to the side of the D70.
  19. Remove the port cover from the D70.
    • Remove the port cover from the D70.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 6,005
