Einleitung
If your Nikon D700 screen needs to be replaced because it is broken/faulty, use this guide to replace your Nikon D700 screen.
Use a spudger and your hands to remove the front grip cover, held together by an adhesive.
Under the rubber cover, use a screwdriver to remove one screw on the top right corner.
Use a Phillips #00 screwdriver to remove the five screws that hold the cover in place.
To remove the screen entirely, use a spudger to unlock the connectors.
Pull the cables out gently using tweezers or your spudger.
The screen should be completely detached from the camera and can now be replaced with a new screen.
