Einleitung
Use this guide to replace the mirror box and viewfinder.
  1. Remove the following 5 screws securing the bottom cover to the camera body:
    • Remove the following 5 screws securing the bottom cover to the camera body:
      • Four 6 mm J000 screws.
      • One 8 mm J000 screw (under lens mount).
  2. Remove three 6 mm J000 screws from under the battery cover.
    • Remove three 6 mm J000 screws from under the battery cover.
    • Gently pull the bottom cover off of the camera body.
    • Remove the following screws from the port area:
      • Two 3.5 mm J000 screws.
      • One 6 mm J000 screw (right above ports).
    • Peel the rear rubber piece off with tweezers.
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    • Pull the eyepiece cover up to remove it.
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
    • Remove four 6 mm J000 screws that secure the SD card cover.
    • Gently pull the SD card cover off.
    • Remove the following screws that secure the back case:
      • One 6 mm J000 screw.
      • One 3 mm J000 screw.
    • Carefully lift the back case off.
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
    • Remove the following screws securing the left motherboard shield:
      • One 2 mm J000 screw (on the bottom).
      • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
    • Gently pry and lift the left motherboard shield off.
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    • Gently lift the right motherboard shield off with the tip of a spudger.
    • Disconnect remaining ribbon cables.
    • Carefully disconnect the red connector with tweezers.
    • Remove four 3.5 mm J000 screws securing the motherboard.
    • Gently pull the port side cover away from the motherboard.
    • Lift the motherboard off.
    • Remove four 6 mm J000 screws securing the tripod plate.
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
    • Disconnect black and white speaker cable.
    • Remove three 6 mm J000 screws securing the image sensor.
    • Carefully lift the image sensor plate out of the camera.
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
    • Remove two 5 mm J000 screws from under the flash.
    • Remove two 3 mm J000 screws securing the front cover.
    • Remove the front cover.
    • Carefully remove the port cover.
    • Deroute the microphone cable.
    • Remove one 4 mm J000 screw from the front.
    • Remove one 8.5 mm J000 screw from the battery compartment.
    • Remove the grip carefully.
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
    • Remove the sticker covering the diopter adjust screw.
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
    • Remove the top case.
    • Remove the Black, Yellow, Green cable from the top case board.
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
    • Remove two 6 mm J000 screws from the left of the shutter.
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
    • Remove two screws from just below and to the sides of the viewfinder.
    • Remove one 5 mm J000 screw from the top right of the camera.
    • Carefully peel back ribbon cable on the bottom left of camera.
    • Remove the left front ribbon cable from top right of circuit board.
    • Remove all three wire connectors.
    • Separate the shutter assembly from the camera body.
    • Pull out ribbon cable from circuit asembly near front left of device.
    • Desolder red & black power leads.
    • Check out our soldering guide for help!
    • Disconnect ribbon cable at the top right of camera.
    • Disconnect ribbon cable at top right of camera.
    • Disconnected ribbon cable at rear right of viewfinder.
    • Remove the two 5.5mm J000 screws
    • Remove the 5.5 mm J000 screw.
    • Remove the viewfinder from the mirror box assembly.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Thomas Willson
Mitglied seit 02.04.2015
320 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-6, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Mitglieder
5 Anleitungen geschrieben
now I know why my camera failed,, the motor overheated
sir francis - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 130
Insgesamt: 7,630
