Was du brauchst
Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
Then unscrew the remaining screws holding the back plate to the LCD.
Then simply remove the plate with the LCD.
Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
Eine weitere Person hat diese Anleitung absolviert.
