Einleitung
After extended use, bulbs often burn out. Replace the flash assembly using this guide. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Was du brauchst
Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
