Einleitung
After extended use, the motherboard of a camera can often stop working. This guide explains how to replace the motherboard of a Nikon D80 camera. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
  1. Using a  Phillips #00  screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover. Using a  Phillips #00  screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Use tweezers to gently flip the small locking flap of the zero force insertion connector up. Pull the orange connector cable out of the zero force insertion connector  using the tweezers. Remove the back cover.
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Use a Phillips #00 screwdriver to remove the six 3.7 mm screws. Remove the back plate that covers the main board. Remove the back plate that covers the main board.
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw. Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  6. Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  7. Using the soldering iron, disconnect the four wires soldered to the main board. For more information on how to solder and desolder connections, please visit this guide. Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
  8. Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver. Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws. Gently remove the motherboard.
    • Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
    • Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
    • Gently remove the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sara Martin
419 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G1, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 47
Insgesamt: 1,027
