Einleitung
Potential damage could occur to the rear LCD screen which could affect performance. For safety purposes, please remove the battery before working with any electronic components.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Using a  Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover. Using a  Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover. Using a  Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Use tweezers to gently flip the small locking flap of the zero force insertion connector up. Pull the orange connector cable away from the main body of the camera using the tweezers. Remove the back cover.
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left. Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  5. Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors. Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  6. Slide out the LCD screen by pulling towards the right. Remove the LCD screen.
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
Abschluss
Sara Martin
419 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G1, Leahy Fall 2017 Mitglied von USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 44
Insgesamt: 758
