Einleitung
Replacing the board holding the GPS, DC in and AV out connectors.
Remplacement de la carte electronique comportant le connecteur GPS, DC IN, et AV out.
Was du brauchst
Remove the three screw in red
Remove the three long screw in orange
Remove the screw in yellow
Toggle up the black plate and disconnect the flex cable
Toggle up the white plate and disconnect the flex cable
Push up the right slide of the connector to free it
Push up the bottom of the connector to free it
Remove the six screws to free the protection plate
Disconnect the white cables
Disconnect the microphone Cable
Disconnect the speaker cable
Remove the two screws to free the PCB
Toggle th PCB from Left to Right
Unsolder the 3 Wires ( Red, Black, Orange )
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
