Einleitung
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Was du brauchst
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
5 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
