Einleitung
Is your film door looking ratty and not working? Don't give up on your camera and try replacing your film door! This guide will explain how to replace the film door in a Nikon N80/F80 Camera.
Was du brauchst
Remove the four 4.8mm screws on the top section of the camera using a PH00 Phillips screwdriver.
Rotate the camera so the bottom plate is accessible.
Remove the seven 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
Remove the two 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
Remove the bottom plate.
Remove the five silver 4.8mm screws on the lens mount using a PH00 Phillips screwdriver.
Extract the lens mount.
Remove the seven 4.8mm screws on front camera plate using a PH00 Phillips screwdriver.
Remove the two 4.8mm screws in the battery compartment of the camera using a PH00 Phillips screwdriver.
Separate the three front camera plates from the camera.
3 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Hi where can buy a replacement door please?
Uscamera.com carries them.
D S -
It's unnecessary to disassemble the camera to this extent. You just need to disconnect the ribbon cable (which involves removing the spring loaded guide next to the door hinge and unlatch the connector underneath) and unscrew the door pivot screw on the underside of the camera. This document lays it out quite nicely:
https://www.jeremymuddphoto.com/blog/202...
Thank you all for the information.
