Einleitung
Is the lens mount in your camera damaged or broken? It might be time to replace it with a new one! This guide will explain how to replace the lens mount (also known as bayonet mount) in a Nikon N80/F80 Camera.
Was du brauchst
Make sure the On/Off switch is in the Off position.
Use a PH00 Phillips screwdriver to remove the five 4.8mm screws on the silver lens mount.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
