Zum Hauptinhalt wechseln
Ninja AF161 Max XL Fan Replacement
Was du brauchst
  1. Ninja AF161 Max XL Fan Replacement, Back Vent Cover: Schritt 1, Bild 1 von 1
    • The back vent cover is directly above where the power cord protrudes.
  2. Ninja AF161 Max XL Fan Replacement: Schritt 2, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #2 screwdriver to unscrew and remove four 1 cm screws from the panel.
  3. Ninja AF161 Max XL Fan Replacement: Schritt 3, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 3, Bild 2 von 2
    • Once unscrewed, remove all four screws in order to remove the back vent cover.
  4. Ninja AF161 Max XL Fan Replacement, Gray Frame: Schritt 4, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement, Gray Frame: Schritt 4, Bild 2 von 2
    • After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
    • Be wary that the two screws are quite tight and will require a bit of torsion to get out.
  5. Ninja AF161 Max XL Fan Replacement: Schritt 5, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 5, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 5, Bild 3 von 3
    • Use the a plastic opening tool or a similar object to wedge between the silver top and black rim.
    • Pry all four sides towards the middle with a plastic opening tool to release the tabs.
    • The tabs on the top will make sounds while being detached from the device.
  6. Ninja AF161 Max XL Fan Replacement: Schritt 6, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the four 2.2 cm screws with a Phillips #1 screwdriver.
  7. Ninja AF161 Max XL Fan Replacement: Schritt 7, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 7, Bild 2 von 2
    • Lay the air fryer on its side.
  8. Ninja AF161 Max XL Fan Replacement: Schritt 8, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 8, Bild 2 von 2
    • Remove six 1.4 cm screws with the TR15 Torx Security Screwdriver.
  9. Ninja AF161 Max XL Fan Replacement: Schritt 9, Bild 1 von 1
    • Keep the device on its side, and unscrew and remove two 1.4 cm screws with a Phillips #1 screwdriver.
  10. Ninja AF161 Max XL Fan Replacement: Schritt 10, Bild 1 von 1
    • The lid can now be lifted off. Remove by prying the bottom apart and lifting.
    • After lifting the lid, you will see the white and yellow wire heads that connect the air fryer display screen to the motherboard.
  11. Ninja AF161 Max XL Fan Replacement: Schritt 11, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 11, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 11, Bild 3 von 3
    • Pinch the white tab and wire head together and pull to release the connector.
    • Take care to not bend the circuit board while attempting removal of this connector. This will damage the circuit board.
  12. Ninja AF161 Max XL Fan Replacement, Fan Motor Assembly Bracket: Schritt 12, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement, Fan Motor Assembly Bracket: Schritt 12, Bild 2 von 2
    • Remove the two 4.7 cm screws and washers using a Phillips #1 screwdriver, and then remove the silver piece on top of the motor.
    • Simply lift the motor up and gently place it to the side.
  13. Ninja AF161 Max XL Fan Replacement, Fan: Schritt 13, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement, Fan: Schritt 13, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement, Fan: Schritt 13, Bild 3 von 3
    • Remove the three 1.4 cm screws, washers, and rubber pieces from the triangular metal piece using a Phillips #1 screwdriver.
    • Remove the triangular metal piece from the device.
  14. Ninja AF161 Max XL Fan Replacement: Schritt 14, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 14, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 14, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the four 2.2 cm screws that secure the top of the device to its base.
    • Once the screws have been removed, gently lift the top of the device off of its base.
    • Be mindful of the wires.
  15. Ninja AF161 Max XL Fan Replacement: Schritt 15, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 15, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 15, Bild 3 von 3
    • Flip the device upside down.
    • Use a 10 mm hex nut screwdriver to remove the 1.4 cm bolt behind the heating plate.
    • Turn the screwdriver to the right to loosen the bolt. Turning the screwdriver to the left will tighten the bolt.
  16. Ninja AF161 Max XL Fan Replacement: Schritt 16, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 16, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the 1.4 cm screw that secures the heating element.
  17. Ninja AF161 Max XL Fan Replacement: Schritt 17, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 17, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 17, Bild 3 von 3
    • Carefully maneuver the fan from under the heating element to remove it from the device. Be cautious of the sharp edges of the fan.
    • Be mindful of the cylindrical piece and hex nut that sit on top of the fan when reassembling.
  18. Ninja AF161 Max XL Fan Replacement: Schritt 18, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 18, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the 1.4 cm screw on the metal dome of the device.
  19. Ninja AF161 Max XL Fan Replacement: Schritt 19, Bild 1 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 19, Bild 2 von 3 Ninja AF161 Max XL Fan Replacement: Schritt 19, Bild 3 von 3
    • Lift the metal dome piece up.
    • Use a Phillips #1 screwdriver to remove the mounting screw and piece.
  20. Ninja AF161 Max XL Fan Replacement: Schritt 20, Bild 1 von 2 Ninja AF161 Max XL Fan Replacement: Schritt 20, Bild 2 von 2
    • Lift the metal dome piece to remove the second fan.
    • Carefully remove the second fan from the device due to its sharp edges.
    • Be mindful of the two washers that sit on top of the fan when reassembling.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jaxon Tueller
432 Reputation
3 Anleitungen geschrieben
Utah Tech University, Team 1-10, Randazzo Fall 2023 Mitglied von Utah Tech University, Team 1-10, Randazzo Fall 2023
UTAHTECH-RANDAZZO-F23S1G10
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 111
Insgesamt: 2,562
