Einleitung
This guide is helpful for replacing the Ninja AF161 Max XL outer gray frame. These steps may be used to remove additional parts from the air fryer.
Was du brauchst
The back vent cover is directly above where the power cord protrudes.
Use a Phillips #2 screwdriver to unscrew and remove four 1 cm screws from the panel.
After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
Use the a plastic opening tool or a similar object to wedge between the silver top and black rim.
Pry all four sides towards the middle with a plastic opening tool to release the tabs.
Keep the device on its side, and unscrew and remove two 1.4 cm screws with a Phillips #1 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
