Einleitung
If your normally piping hot cup of coffee is coming out at room temperature then the water heater may be to blame. This replacement involves removing a number of small screws so it may be a good idea to have the iFixit magnet pad nearby. Follow this guide to replace your device’s water heater and restore heat to your Ninja Coffee Bar.
Was du brauchst
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
Remove the three 6 mm screws with the Phillips #1 screwdriver.
Remove the plastic cover.
Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
Remove the single 6mm #1 Phillips-head screw from the side of the unit.
Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
Squeeze clip and separate signal wiring.
Using wire stripper/crimping tool, uncrimp wiring connectors
