Einleitung
The water reservoir hanger is located on the left side of the brew basket and filter. This small component is crucial for making sure the water reservoir is secure and attached to the rest of the device. Follow this guide to replace the water reservoir hanger and resecure your water reservoir.
Was du brauchst
Remove single 6mm #1 Phillips head screw from the side of the unit and four 6mm screws from under the basket area.
Inside the panel, remove the two 6mm #1 Phillips head screws. Remove and replace water reservoir clip as necessary.
