Zum Hauptinhalt wechseln
Ninja Coffee Bar® Single-Serve System Frother Replacement
Was du brauchst
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: Schritt 1, Bild 1 von 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: Schritt 1, Bild 2 von 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 2, Bild 1 von 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 2, Bild 2 von 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 3, Bild 1 von 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 3, Bild 2 von 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 4, Bild 1 von 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 4, Bild 2 von 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: Schritt 4, Bild 3 von 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Abschluss
CJ Berg
444 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Mitglied von UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 1,486
