Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This is very similar to replacing the tubes in the device, which is show in another repair guide created for the ninja coffee bar. Be very careful with the screws because they are very small. We would suggest the magnetic mat provided by iFixit so you don't lose the screws. Just like the tube repair guide, be careful removing the protective plate because there are a lot of wires that can not be disconnected. Also, make sure to take some pictures of the wiring just incase some of them do slip loose.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Remove bottom cover
  2. Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Remover tube protection plate
  3. Detach valve tubes from valve by squeezing pins and pull tubes away from valve Detach valve tubes from valve by squeezing pins and pull tubes away from valve
    • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
Abschluss
Naser Aldousari
304 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S13-G69, Cagle Fall 2017 Mitglied von USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 Mitglieder
Where can I get the replacement water valve?
Mark Peters - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 7
Letzten 30 Tage: 23
Insgesamt: 631
