Zum Hauptinhalt wechseln
Ninja Coffee Bar CF086 Water Heating Element Replacement
Was du brauchst
  1. Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: Schritt 1, Bild 1 von 2 Ninja Coffee Bar CF086 Water Heating Element Replacement, Water Heating Element: Schritt 1, Bild 2 von 2
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 3, Bild 1 von 1
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 4, Bild 1 von 1
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 5, Bild 1 von 1
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 6, Bild 1 von 3 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 6, Bild 2 von 3 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 6, Bild 3 von 3
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 7, Bild 1 von 2 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 7, Bild 2 von 2
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 8, Bild 1 von 2 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 8, Bild 2 von 2
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 9, Bild 1 von 2 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 9, Bild 2 von 2
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 10, Bild 1 von 3 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 10, Bild 2 von 3 Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 10, Bild 3 von 3
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Water Heating Element Replacement: Schritt 11, Bild 1 von 1
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
Abschluss
To finish reassembling your device, follow steps 2-7 in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
David Ton
630 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G5, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G5, Thompson Fall 2017
USFT-THOMPSON-F17S1G5
4 Mitglieder
2 Kommentare
Where is the heating element available for sale.
ausbinp - Antwort
I need a element for a CM401 model, any help?. gene@wholedamarea.com
Lester Bouler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 4,257
