Zum Hauptinhalt wechseln
Ninja Foodi DZ401 Top Cover Replacement
Was du brauchst
  1. Ninja Foodi DZ401 Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 3 Ninja Foodi DZ401 Top Cover Replacement, Top Cover: Schritt 1, Bild 2 von 3 Ninja Foodi DZ401 Top Cover Replacement, Top Cover: Schritt 1, Bild 3 von 3
    • Position the air fryer so that the front is facing you and the top is accessible.
    • Using opening picks and a metal spudger, pry open the silver ring on the front, right corner.
    • Place an opening pick on the left side of the corner to hold the ring away from the cover.
    • Slide the metal spudger underneath the silver ring. When you find a notch, place the metal spudger next to the notch and pry up to release it.
    • This process requires a significant amount of force to be applied to the silver ring and top cover of the air fryer. It may result in damage to both tools and the air fryer cover.
  2. Ninja Foodi DZ401 Top Cover Replacement: Schritt 2, Bild 1 von 1
    • Using a metal spudger, pry open the plastic top cover by inserting into the slots and pushing up on the tabs.
    • There are three openings on the front, one on each side, and four on the back of the unit.
    • The metal spudger may scratch or damage the cover if care is not taken.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 24
Insgesamt: 91
