Einleitung
This guide will teach you how to replace the spring in the button of your blender.
Was du brauchst
Remove the two highlighted screws with a Phillips #2 Screw Driver
Gently pull off the top.
Pull out the highlighted spring.
Now wash the button with soap and water, and follow the guide backwards to reassemble.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
turns out it was a security torx. how annoying.
