Einleitung
Use this guide to replace the LED on the circuit board of your device.
Was du brauchst
Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver.
Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
Locate the LED you wish to replace and note its position on the opposite side of the circuit board.
Desolder both of the LED leads and remove the LED light. Note the orientation of LED, this is important for replacing the LED. The Replacement LED needs to be soldered in the same orientation.
