Einleitung
If your blender is too loud, your fan may be damaged or loose. This guide will show you how to replace a broken or damaged fan.
Was du brauchst
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
Pull the power cord through the mid-section opening.
Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
Slide the cover all the way to the end of the power cord.
Use a wrench or a pair of pliers to help remove the nut on top of the fan. Holding the fan itself will help make the process easier.
Ein Kommentar
I did that but the other fan is the one that is lock and do not turn on. The white one in the middle. How can I fix it.
