Zum Hauptinhalt wechseln
Ninja Professional Blender BL660 Suction Cups on Base Replacement
Was du brauchst
  1. Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: Schritt 1, Bild 1 von 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement, Suction Cups on Base: Schritt 1, Bild 2 von 2
    • Using the Phillips #1 screwdriver, remove the 5 screws holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Suction Cups on Base Replacement: Schritt 2, Bild 1 von 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: Schritt 2, Bild 2 von 2
    • Turn the base panel upside down to reveal the suction cup feet.
  3. Ninja Professional Blender BL660 Suction Cups on Base Replacement: Schritt 3, Bild 1 von 1
    • Push the stopper on the suction cup foot through the bottom panel using the iFixit plastic opening tool.
  4. Ninja Professional Blender BL660 Suction Cups on Base Replacement: Schritt 4, Bild 1 von 2 Ninja Professional Blender BL660 Suction Cups on Base Replacement: Schritt 4, Bild 2 von 2
    • Once stopper has passed through the bottom panel, pull suction cup foot out.
    • Replace suction cup feet as needed.
    • Ninja does not sell suction cup feet. You will need to obtain them from other third party vendors.
Abschluss
Ein Kommentar
Where did you get the suction cups from?
camoramirez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 63
Insgesamt: 4,978
