Zum Hauptinhalt wechseln
Ninja Ultima BL810 Power Plug Replacement
Was du brauchst
  1. Ninja Ultima BL810 Power Plug Replacement, Power Plug: Schritt 1, Bild 1 von 3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: Schritt 1, Bild 2 von 3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: Schritt 1, Bild 3 von 3
    • Unscrew the Phillips #0 11mm screws.
    • Unscrew the Torx Security #10 11mm screw.
  2. Ninja Ultima BL810 Power Plug Replacement: Schritt 2, Bild 1 von 2 Ninja Ultima BL810 Power Plug Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
    • Pull the bottom covering off of the blender.
  3. Ninja Ultima BL810 Power Plug Replacement: Schritt 3, Bild 1 von 2 Ninja Ultima BL810 Power Plug Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the two Phillips #2 9mm screws.
    • Remove the plastic block.
  4. Ninja Ultima BL810 Power Plug Replacement: Schritt 4, Bild 1 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 4, Bild 2 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the four Phillips #2 11mm screws.
    • Remove the plastic covers.
    • Removing the top cover and then rotating the bottom cover into the same orientation works best.
  5. Ninja Ultima BL810 Power Plug Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the three Phillips #2 9mm screws.
    • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
  6. Ninja Ultima BL810 Power Plug Replacement: Schritt 6, Bild 1 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 6, Bild 2 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 6, Bild 3 von 3
    • Pull the power cord through as shown to create slack.
    • Remove plastic casing by lifting upwards.
  7. Ninja Ultima BL810 Power Plug Replacement: Schritt 7, Bild 1 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 7, Bild 2 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 7, Bild 3 von 3
    • Follow the power plug cords to find the right plastic caps.
    • Squeeze the caps with pliers to loosen the grip.
    • Pull the plastic caps off the twisted wires.
  8. Ninja Ultima BL810 Power Plug Replacement: Schritt 8, Bild 1 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 8, Bild 2 von 3 Ninja Ultima BL810 Power Plug Replacement: Schritt 8, Bild 3 von 3
    • Untwist the two wires from each other and pull the zip tie off.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S9-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 611
