Einleitung
This guide will demonstrate how to disconnect the power plug.
Was du brauchst
Unscrew the Phillips #0 11mm screws.
Unscrew the Torx Security #10 11mm screw.
Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
Pull the bottom covering off of the blender.
Unscrew the four Phillips #2 11mm screws.
Pull the power cord through as shown to create slack.
Remove plastic casing by lifting upwards.
Follow the power plug cords to find the right plastic caps.
Squeeze the caps with pliers to loosen the grip.
Pull the plastic caps off the twisted wires.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
