Zum Hauptinhalt wechseln
Nintendo 2DS Battery Replacement
Was du brauchst
  1. Nintendo 2DS Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: Schritt 2, Bild 1 von 2 Nintendo 2DS Battery Replacement: Schritt 2, Bild 2 von 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: Schritt 3, Bild 1 von 3 Nintendo 2DS Battery Replacement: Schritt 3, Bild 2 von 3 Nintendo 2DS Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Abschluss
33 weitere Nutzer:innen haben diese Anleitung absolviert.
Fina Beauchamp
3.024 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 70-1, Forte Winter 2015 Mitglied von Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Mitglieder
35 Anleitungen geschrieben
4 Kommentare
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Antwort
This didnt help my problem
Artemy Matveev - Antwort
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Antwort
or maybe its just not working ludovic 🫡
Natalia Rabago -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 165
Letzte 30 Tage: 772
Insgesamt: 40,743
