Einleitung
This guide for the Nintendo 2DS will teach you how to access the trigger buttons to remove them for cleaning or replacement.
Was du brauchst
Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
Remove the cable from the connector
Pull the trigger button away from the device to remove it.
22 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Nice job! My right button was jammed for at least two years. Now I can finally demolish my friends in Mariokart.
Can’t seem to get the second set of screws to budge at all.
now what????
