Zum Hauptinhalt wechseln
Nintendo 2DS Wi-Fi Card Replacement
Was du brauchst
  1. Nintendo 2DS Wi-Fi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip over the 2DS.
  2. Nintendo 2DS Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Nintendo 2DS Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Nintendo 2DS Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the game cartridge, SD card and stylus if your console has them inserted.
  3. Nintendo 2DS Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Undo the 2 Phillips #00 screws.
    • The screws will not completely detach from the battery cover.
  4. Nintendo 2DS Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Nintendo 2DS Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery cover up and pull it out.
  5. Nintendo 2DS Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Nintendo 2DS Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Lift up the battery and remove it.
  6. Nintendo 2DS Wi-Fi Card Replacement, Wi-Fi Card: Schritt 6, Bild 1 von 1
    • Remove the 10 Phillips #00 screws.
  7. Nintendo 2DS Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the rear panel.
    • There's a ribbon cable on the rear panel attached to the motherboard, so be very careful not to damage that cable!
  8. Nintendo 2DS Wi-Fi Card Replacement: Schritt 8, Bild 1 von 1
    • Pull up the Wi-Fi card from the left side.
  9. Nintendo 2DS Wi-Fi Card Replacement: Schritt 9, Bild 1 von 1
    • Use a spudger or your fingernail to carefully pull up on the right side of Wi-Fi card. This'll disconnect the Wi-Fi card.
    • There's a cable behind the Wi-Fi card, so be very careful removing it!
  10. Nintendo 2DS Wi-Fi Card Replacement: Schritt 10, Bild 1 von 1
    • Flip over the Wi-Fi card.
  11. Nintendo 2DS Wi-Fi Card Replacement: Schritt 11, Bild 1 von 1
    • Use a spudger or your fingernail to remove the cable from the Wi-Fi card.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Ella
2.251 Reputation
10 Anleitungen geschrieben
3 Kommentare zur Anleitung
Where is the guide for the 2DS Zelda version? I just opened mine up, and there IS NOT a wifi module card anywhere to be seen?! Did they move it UNDER the motherboard? I can not find any guides to the green and brown Zelda 2DS. Mine won’t update or connect to anything now.
Jeremy Patton - Antwort
It is the same. If you cannot see a Wi-Fi card, there probably is no Wi-Fi card.
Ella -
The wifi chip linked is a "2878D-J27H02301" but the one shown in the picture for the 2DS is a "DWM-W082", will either work or do I need to get a DWM-W082?
NullImmer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 27
Letzte 30 Tage: 190
Insgesamt: 5,525
