Zum Hauptinhalt wechseln
Nintendo 3DS Back Cover Replacement
Was du brauchst
  1. Nintendo 3DS Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Back Cover Replacement: Schritt 2, Bild 1 von 2 Nintendo 3DS Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
Abschluss
18 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.455 Reputation
127 Anleitungen geschrieben
2 Kommentare
Anybody know where to buy replacement back covers for this original 3DS model? I’m finding that a lot of used 3DS’s from this era have 3rd party battery packs and the original cover is lost.
CORED3SIGN - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 99
Letzte 30 Tage: 461
Insgesamt: 25,235
