Einleitung
Having trouble with your 3DS' IR port? A new IR board could help.
Was du brauchst
Unscrew the four Phillips #00 screws along the top of the back cover.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Lift the bottom edge of the lower case off the rest of the 3DS.
Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Remove the lower case from the device.
Use the flat end of a spudger to lightly pry the IR board off the motherboard.
Grab the edges of the IR board with two fingers and lift it from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
