Zum Hauptinhalt wechseln
Nintendo 3DS Lower Case Replacement
Was du brauchst
  1. Nintendo 3DS Lower Case Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Lower Case Replacement: Schritt 2, Bild 1 von 2 Nintendo 3DS Lower Case Replacement: Schritt 2, Bild 2 von 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Lower Case Replacement, Battery: Schritt 3, Bild 1 von 3 Nintendo 3DS Lower Case Replacement, Battery: Schritt 3, Bild 2 von 3 Nintendo 3DS Lower Case Replacement, Battery: Schritt 3, Bild 3 von 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Lower Case Replacement, Lower Case: Schritt 4, Bild 1 von 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Lower Case Replacement: Schritt 5, Bild 1 von 3 Nintendo 3DS Lower Case Replacement: Schritt 5, Bild 2 von 3 Nintendo 3DS Lower Case Replacement: Schritt 5, Bild 3 von 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.503 Reputation
127 Anleitungen geschrieben
2 Kommentare
Is this guide for the original 3ds?
Glenn Racz - Antwort
yessir it is
Electronik -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 33
Letzte 30 Tage: 120
Insgesamt: 15,705
