Zum Hauptinhalt wechseln
Nintendo 3DS Lower Display Assembly Replacement
Was du brauchst
  1. Nintendo 3DS Lower Display Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Lower Display Assembly Replacement: Schritt 2, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Lower Display Assembly Replacement, Battery: Schritt 3, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement, Battery: Schritt 3, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement, Battery: Schritt 3, Bild 3 von 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Lower Display Assembly Replacement, Lower Case: Schritt 4, Bild 1 von 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Lower Display Assembly Replacement: Schritt 5, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 5, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 5, Bild 3 von 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Lower Display Assembly Replacement, Circle Pad Joystick: Schritt 6, Bild 1 von 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  7. Nintendo 3DS Lower Display Assembly Replacement: Schritt 7, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 7, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 7, Bild 3 von 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. Nintendo 3DS Lower Display Assembly Replacement: Schritt 8, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 8, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 8, Bild 3 von 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
  9. Nintendo 3DS Lower Display Assembly Replacement: Schritt 9, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 9, Bild 2 von 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
  10. Nintendo 3DS Lower Display Assembly Replacement, SD Board: Schritt 10, Bild 1 von 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. Nintendo 3DS Lower Display Assembly Replacement: Schritt 11, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. Nintendo 3DS Lower Display Assembly Replacement: Schritt 12, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 12, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 12, Bild 3 von 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
  13. Nintendo 3DS Lower Display Assembly Replacement, Wi-Fi Board: Schritt 13, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement, Wi-Fi Board: Schritt 13, Bild 2 von 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. Nintendo 3DS Lower Display Assembly Replacement: Schritt 14, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 14, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 14, Bild 3 von 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
  15. Nintendo 3DS Lower Display Assembly Replacement, Motherboard Assembly: Schritt 15, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement, Motherboard Assembly: Schritt 15, Bild 2 von 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. Nintendo 3DS Lower Display Assembly Replacement: Schritt 16, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 16, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 16, Bild 3 von 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  17. Nintendo 3DS Lower Display Assembly Replacement: Schritt 17, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 17, Bild 2 von 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  18. Nintendo 3DS Lower Display Assembly Replacement: Schritt 18, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 18, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 18, Bild 3 von 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  19. Nintendo 3DS Lower Display Assembly Replacement: Schritt 19, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 19, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 19, Bild 3 von 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  20. Nintendo 3DS Lower Display Assembly Replacement: Schritt 20, Bild 1 von 1
    • Remove the motherboard assembly from the rest of the device.
  21. Nintendo 3DS Lower Display Assembly Replacement, Lower Display Assembly: Schritt 21, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement, Lower Display Assembly: Schritt 21, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement, Lower Display Assembly: Schritt 21, Bild 3 von 3
    • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
    • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
  22. Nintendo 3DS Lower Display Assembly Replacement: Schritt 22, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 22, Bild 2 von 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the touchscreen ribbon cable ZIF socket.
  23. Nintendo 3DS Lower Display Assembly Replacement: Schritt 23, Bild 1 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 23, Bild 2 von 3 Nintendo 3DS Lower Display Assembly Replacement: Schritt 23, Bild 3 von 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
    • Pull the ribbon cable out of the connector with a pair of tweezers.
    • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
  24. Nintendo 3DS Lower Display Assembly Replacement: Schritt 24, Bild 1 von 2 Nintendo 3DS Lower Display Assembly Replacement: Schritt 24, Bild 2 von 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD data ribbon cable ZIF socket.
  25. Nintendo 3DS Lower Display Assembly Replacement: Schritt 25, Bild 1 von 1
    • Grasp the lower display assembly and pull it directly away from the motherboard.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.455 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 93
Insgesamt: 8,531
