Zum Hauptinhalt wechseln
Nintendo 3DS Motherboard Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: Schritt 1, Bild 1 von 2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: Schritt 1, Bild 2 von 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: Schritt 2, Bild 1 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 2, Bild 2 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 2, Bild 3 von 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: Schritt 3, Bild 1 von 2 Nintendo 3DS Motherboard Assembly Replacement: Schritt 3, Bild 2 von 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: Schritt 4, Bild 1 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 4, Bild 2 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: Schritt 5, Bild 1 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 5, Bild 2 von 3 Nintendo 3DS Motherboard Assembly Replacement: Schritt 5, Bild 3 von 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  6. Nintendo 3DS Motherboard Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the motherboard assembly from the rest of the device.
Abschluss
David Hodson
150.455 Reputation
127 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,577
