Zum Hauptinhalt wechseln
Einleitung
This guide will walk you through the process of opening and replacing the left and right speakers.
  1. Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing. Underneath the rubber is a silver sticky
    • Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing.
    • Underneath the rubber is a silver sticky
    • Using the PH00 screw driver, remove the screws.
  2. Using a blue spudger, slide it around the sides to open the casing. The casing will become loose,  and just lift the casing off.
    • Using a blue spudger, slide it around the sides to open the casing.
    • The casing will become loose, and just lift the casing off.
  3. Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  4. Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  5. Once the screws are loosened, pry open the back cover.
    • Once the screws are loosened, pry open the back cover.
  6. The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a pointed tool.
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a pointed tool.
  7. Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
    • Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  8. Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well. Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  9. To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards. Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard. Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  10. Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  11. Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
    • Slide the ribbon out of the ZIF connector.
  12. Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  13. Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  14. Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  15. Using tweezers, gently pull the five marked ribbons out of the ZIF connectors along the sides of the motherboard. These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them! Note that in some models the upper-most connector may have a lock. Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • Using tweezers, gently pull the five marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them! Note that in some models the upper-most connector may have a lock.
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  16. Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  17. Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard. Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different.
  18. Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing. Underneath the rubber is a silver sticky
  19. Using a blue spudger, slide it around the sides to open the casing. The casing will become loose,  and just lift the casing off.
  20. The speakers are on the left and right side of the 3DS, and are held down by tape. Before lifting the tape up, the speaker on the right side has two input films. Carefully detach each speaker film from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them Slowly lift the tape from the speaker.
    • The speakers are on the left and right side of the 3DS, and are held down by tape.
    • Before lifting the tape up, the speaker on the right side has two input films. Carefully detach each speaker film from their respective ZIF (zero insertion force) connectors. These are the paper thin ribbons that have orange stripes along them
    • Slowly lift the tape from the speaker.
    • The speakers are soldered onto the circuit board.
Abschluss
Ryan Butler
1.359 Reputation
9 Anleitungen geschrieben
iFixit, Team 1-1, Weber Winter 2016 Mitglied von iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Mitglieder
21 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 18
Letzten 30 Tage: 62
Insgesamt: 725
