Zum Hauptinhalt wechseln
Nintendo 64 Rumble Pak Battery Replacement
Was du brauchst
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: Schritt 1, Bild 1 von 1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: Schritt 3, Bild 1 von 1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: Schritt 4, Bild 1 von 3 Nintendo 64  Rumble Pak Battery Replacement: Schritt 4, Bild 2 von 3 Nintendo 64  Rumble Pak Battery Replacement: Schritt 4, Bild 3 von 3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Abschluss
Carly Bowen
304 Reputation
1 Anleitung geschrieben
Texas Tech, Team 3-6, Rauch SU 2015 Mitglied von Texas Tech, Team 3-6, Rauch SU 2015
TTU-RAUCH-SU15S3G6
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 4,011
